Wi-Fi vs occusync 2.0.
Yes, Ocusync wins by far.
Wi-Fi is designed for short ranges up to about 100m, so that they could customise it to get usable bandwidth out of it at 1km or more is already pretty impressive. Ocusync is built using customised LTE (4G) cellular equipment which is designed for more range in the first place.
I have not found this at all. In the exact same flying locations, flying one directly after the other, my Mavic Air 1 in FCC mode outperforms my Mini 2 in CE mode. Pretty disappointing from the Mini 2.
That's not exactly correct. Ocusync 2.0 uses the same frequencies as Wi-Fi. DJI designed it as a Software Designed Radio (SDR) that would be able to use off-the-shelf Wi-Fi chipsets.
FWIW, LTE range is largely defined by equipment on the towers. If Ocusync was based on LTE, you wouldn't be able to fly a drone in an LTE dead zone.
I didn't say it was using the LTE network, just that they used LTE chipsets and modulation/tech to implement their own connection, that's obviously not dependent on any existing network.
That's been determined by people reverse-engineering the boards and RF transmission.
Do you have anything that documents the use of LTE chip sets? You can't just use a LTE chipset and broadcast your own protocol. LTE usage is strictly regulated. Ocusync 2.0 is documented on DJI's own site to use the 2.4 and 5.8 Ghz bands, which is where Wi-Fi operates. Here's a nice writeup of how the Ocusync protocol works and how it uses Wi-Fi hardware, but their own protocol.
Data comes from the dji reverse engineering groups.
Again it's LTE tech but applied in a custom way and in the license free bands, not actual LTE as in cellular.
Are you sure about the LTE hardware? For example, the Mavic Air 2 uses a dual-band Wi-Fi chip from Imagination Technologies (source).
At any rate, the range of the radio is going to be limited by the antenna, broadcast power, and protocol used.
UR7CR
