You Know You're Not Cut For Drone Flying When..
MavicKhan
Cascais, Portugal
Let's have some fun! :)
Complete this in separate replies and I'll add them up to the OP, as kind of an amusing primer.
You Know You're Not Cut For Drone Flying When...
I'll start...
(The best ones will be edited into the OP, as a consolidation of sorts for said primer)
...You think flying indoors for your maiden flight is a great and fun idea.
Hey, did that on purpose!!! (I live near an airport so "outside" did not seem to be a good idea, my yard is full of trees, driving to an area to fly only to find out it needs "upgrades" would be a bummer, and the main reason was I knew it could not "fly away"!)
No issues at all doing that. (Right up till the RC disconnected and it was set to RTH :):oops:)
Life is an adventure!!
You have an overwhelming urge to feed frankfurters slowly, delicately and seductively, through spinning props.
The other way around is probably even funnier.
You know you're cut out to be a drone pilot because:........
When you update your firmware and it fails and you go and fly it anyway, and then it crashes.
You know you are not cut for drone flying when.... you have no spatial awareness or sense of direction.. and when your 6 year old kid operates it better than you do
Reactions: Kestrel
Pocki
