You said it and we just made it - Lykus NEW hard case for Mavic Air 2S and RC Pro
This is the lanyard I got for my SC. The same one works perfectly for the RC Pro. Same size screw attachments.
I will consider that option, thanks. I suspect that will indeed do it.
Mine fits ok. I will probably get the lanyard but I like the case. Not quite as solid as my GPC cases but half the price. Overall I would definitely recommend. Lots of accessory space the GPC just does not have.
Got mine yesterday. Like it. Just let it sit outside with the lid open for a couple of hours as the materials have a strong chemical odor.
Reactions: merak75
Got mine today. It works perfectly. Left mine open for a couple hours. The foam in the lid is all that still smells a bit like chemicals. I'm sure that will go away eventually.
I ordered mine same day as you. How was the tracking on yours. Mine is up to 28. Middle Tennessee, just north of Nashville. Seems like it should have been here already.
Why do you make the case to carry 5 extra batteries? I’m sure not too many people carry that many batteries. I would like a case that just has 3 extra spots for batteries and use the extra room for extra accessories instead of 5 batts.
Agree, Combine 3 of the battery locations for one deep rectangle compartment. Perfect for many FPV glasses or many other accessories. That leaves 2 battery compartments and the 3rd on the aircraft (=Fly More Combo).
The foam can be modified to your liking, its not locked in. Two extra spots will cover the majority of people with the flymore. I have a bunch from buying and selling Air 2 and 2S that I had before the one I have now but had I not I would just use the slots for other things like the charger for the RC Pro, props and use the prop slot for other filters. My case still has space even with a full compliment of batteries in the middle pocket.
So, overall this case is great. I fit everything I needed/wanted. If I had to complain about something it would be that when you stand it up it doesn’t balance well. The “legs” should extend all the way.
Reactions: mobilehomer
My sentiments exactly. I am going to Super Glue some extensions to the legs. It won't take much, maybe a half inch.
Reactions: merak75
Yes, I had no problem cutting out room for the RC-Pro's lanyard eye-bolts.
I had to modify a case last year. My wife does arts and crafts, so I had this kit. It worked awesome:
Hot Knife Foam Cutter Hot Wire Styrofoam Engraving Tip 3 in 1 Tools Kit by Calcor Amazon.com
Thx if you can post a close-up of the cuts you made that would be great.
I bought this lanyard:
Brand: SEASKYRC
It has foldable stainless steel mounts. Fits in the Lykus hard case just fine, no need to cut anything. Even though it has the anti loosening washers, I still put a dab of blue locktite on the threads.
I bought both the leather and the denem one for the heck of it, and both are pretty soft and comfortable to use. There are clips to remove the lanyard from the mounts. I use whichever one I am in the mood for. 😎👍
Keith J
