100MP and 25MP DNG please
I think it's going to be fantastic for my work.
The extra speed will be a real plus.
The only little niggle I picked up was that I wasn't able to catch it and had to land on the ground.
I'll have to investigate that further.
You must be one of the first people on the forum with the drone, would be good to hear your thoughts on a first impressions thread or similar.
Reactions: Mrktn
Mines stuck in an Argos warehouse, wondering if I’m gonna pull the trigger on him lol
But likewise, looking forward to seeijg what @Meta4 thinks first impressions
  • Haha
Reactions: Johnmcl7
According to drone supremacy channel on YouTube, it seems that this drone like all the recent ones still has sharpness problem in some situations. Wonder when DJI is going to address that issue by chosing to use high quality glass and inforce the control quality to avoid decentered lenses
Reactions: Mrktn
Seems to be hot and miss. @Filmarik says he has a diamond Mavic 3 Pro with perfectly centred lens, perfect sharpness across the frame but the jury’s out with the M4P.
Reminds me to get out with my Air 3s and do more stills. Video wise I can’t complain, but these kind of issues rarely show to the eye on flying movement
I posted some sample images back in post #34 that you can download to check.
Meanwhile here are a few test images I shot
There are 4 sets of 3 comparing the different cameras and 4 extra grab shots from the main camera.
Here's a download link for the whole set:
Or you can download individual images separately.
The photos are jpg straight from the camera.
I was impressed with the detail in all three cameras.
Thanks for posting those. I took a look at the full screen versions on Smugmug but will download some samples from your link this weekend when I get some more time. The images from all of the cameras do look good for all of the cameras and appear to be sharp from the centre to the edges. If I was selling my images and making a living from photography I would most likely upgrade to the Mavic 4 Pro.
I am curious to know, did you upgrade to the new RC Pro 2 controller as well or did you purchase the package with the RC-N3 controller and use your current tablet?
Chris
I am, like you used to work with FF DSLR cameras which all have 3:2 aspect ratio sensor. But I have options to put on my FF 17mm lens or 24 or 50 or whatever. From ultrawide angle to tele if I want. My point with this M4P 3:2 sensor is that with 4:3 ratio I'd have choice which area to crop to get to 3:2 if that is what I want as my output format. I can keep all the bottom part and only crop the top or keep all the top and crop from bottom. And then there are situations when I want the more squarish format when the subject requires it and that is when 4:3 comes handy and I can use the full realestate of the sensor without cropping.
What I am saying is that the 28mm lens has naturally narrower angle of view compared to 24mm and now with the smaller 3:2 sensor the vertical coverage has been cut to about half. When shooting mostly architecture this makes a massive difference! And all of this without any mention in the spec sheet!!
That is the point I was trying to convey.
I agree it's not ideal, but I'm looking forward to shooting some vertical panoramas, meaning shooting in vertical mode with shots from left to right and then stitching them together. I'm curious how that will work with static subjects. It could be a step up from the Mavic 3, but what we really need is at least an APS-C sensor with interchangeable lenses. Maybe Sony will change its mind and releases an improved version of its drone. No one else seems to care about photographers' needs.
Reactions: AlexisFraNorge
I am sure the stitched panos will look pretty awesome. Bear in mind though that the gimbal tilt movement in vertical mode is very limited. Other than that I believe you'll be very happy with the results.
https://smugmug.link/THkgqWnorFxyeA7w7 Or you can download individual images separately.
Thanks for those, very useful. Very sharp on the buildings, the trees less so. I'm mainly interested in landscapes, so hoping editing Raws in LrC will improve foliage.
I went with the RC2.
There weren't any options to get it with the RC-N3, but I'd prefer to use my tablet and have the bigger screen area to work with.
I'd like confirmation that it will work before grabbing one - they are a lot cheaper than the RC2 pro.
Have you seen packages that included the RC-N3?
Haven't seen any packages yet with the RC-N3 but I watched a review a few days ago and the reviewer said that there would be packages with the RC-N3 available. Not sure how accurate that was. Here in Canada they are currently being sold with the RC2 and RC Pro 2. However I can't see DJI forcing people who want to use a larger screen than the RC2 to have to use the Pro controller. I would imagine the RC-N3 will get a firmware update soon so that it will be compatible with the Mavic 4 Pro.
I have the RC-N3 and checked to see if there were any updates or if the Mavic 4 appeared in the 'Select Aircraft Model' and so far its not there.
Chris
Chris
I doubt there will be to force you to get the RC Pro 2 if you want a bigger screen. I hope I'm wrong.
They probably want people to at least buy the RC2 package. I think they will update the RC-N3 to allow people to use their own device but after the initial launch buying dies down.
Chris
Reactions: UAVquadman
Chris
that would be great as for sure I like a 10" tablet as it helps when flying to get shots like this.
It looks good to me, pretty well centered at that. This is encouraging, hopefully I can get my hands on one sooner rather than later.
A question, can you use "Free Panorama" mode with all three cameras and is it true free form as in not just limited to ultra wide panoramic photos but include square, vertical, horizontal, etc? My primary use of my Mavic 3 Pro drone is using the medium and telephoto cameras to shoot 20-40 frames to stitch together much larger file sizes for fine art and high end commercial output. Being able to automate this would be a serious game changer / time saver for me.
Thanks for posting!
Thanks a lot for your uploaded images. I would like to ask if you could mind to post some DNG files as well? From another set of images provided by another user which compared M3P to M4P in the same shooting environment, I could clearly see the degrade of M4P image quality in terms of sharpness.
Here are 4 sets of jpg+dng images from each of the 3 cameras, shot at the lower resolution.
I shot some comparisons yesterday to see how the 100/48/50 MP resolutions comp[are and I'm not yet convinced that the higher resolutions show any appreciable improvement.
Will have to do some more testing of that to be sure.
That's surprising.
Can you point me to that comparison?
Isn't it a known trade off with a quad bayer filter; improved low light and noise reduction for a bit less sharpness? You are not magically going to get more sharpness than the sensor without the filter can achieve.
it's 25mp so this may help balance it out. (versus 20mp non/bayer)
Reactions: GadgetGuy
Thanks for those, very useful, and probably sold me on it. I've been dithering between Mavic 4 Pro and 3 Pro. I doubt I would bother with the 100MP files, so useful to see what the 25MP DNGs can do, even without full support in LrC. The JPGs are pretty good too. Were these on default sharpening? Some recommend -2. There's only the faintest trace of moire on the island building roof in DJI_20250519101545_0041_D.JPG. I'm sure the Air 3S would have created a load more, so the Hasselblad input may have helped here.
jdcleland
