100w home charger for air 3s
jojonono
I just bought the air 3s upgrading from my deceased air 2s, I found out however I need to buy a power brick, I will probably stick to the 3 batteris right now and I usually shoot up to 6 or 8 hours events which requires continuous battery use and flights with no downtime, I can't figure out however which 100w powerbrick will work with the dji hub or even if I upgrade to the:
LKTOP 200W Air 3/Air 3S Battery Fast Charger Hub for DJI/Specta Air 3 Series Drone USB-C Power Adapter, with Gather Average Electricity/Fast Charging/Storage/LED/Alarm Mode, LED Display Screen
This one needs TWO 100w for max performance...
My second use case is charging the drone while in the car for work related, can I use a 200w inverter to charge my batteries while in the car using any of the above two chargers or inverter is not meant for that ??
Finally am considering this but it charges two batteries only simultaneously within 75minutes...
Is it any good ?
Plz guide me to get best chargers while not spending a lot on money on chargers...
Reactions: Oren and sdcaver
Is it any good ?
Many chargers don't deliver their advertised power; you can depend on Anker and Ugreen chargers. I have a couple of the Ugreen 100W chargers and deliver power as advertised. They make several models so search for the company name in Amazon.
Reactions: Rchawks and Cafguy
Is it any good ?
I bought this one for my Air 3S from Amazon and it is great:
Hanatora Parallel Fast Charger for DJI Air 3S,Air 3,Rapid simultaneous Battery Charging Hub,Multi Drone Charge Accessories​
Reactions: Cafguy
This is what I used, getting exactly 100 watts to the charging hub.
you can use 100w or 200w charger, but dji 3s battery charger takes only 60w max ia charging.
no. in drone charging takes only max 30w. measured. only my avata2 and 3s battery charger takes both 60w, my mini4pro or neo or my flip battery chargers takes max 30w only as have smaller low power batteries
I'm not sure what you are disagreeing with. This thread is about the Air 3S.
So let me make this as clear as I can. The 3S charging cradle will in fact take 100W with the correct charging brick and cable - with a battery drained to below 10%. This was proven in my post here (MEASURED):
https://mavicpilots.com/threads/another-alternative
Further more, this reviewer also confirmed 100W into an Air 3 charging cradle - again - using the correct brick and cable: MEASURED
Also, here is my VIMEO video showing my 3S charging cradle taking 100 watts charging (MEASURED)
Finally, I can easily get around 60-65 watts in-drone charging with my 3S (measured).
even dji makes 65w chargers as no any dji drone charging cradle take more than 60-62w with good copper cable. its like many shows iphone can charge at 22w , its no more takes 14w with any top cable or top charger. also i think batteries works longer if charge them with slower charging hubs
DJI also makes a 100W charging brick - compatible with the 3S. This is common knowledge. You can view it here;
Buy DJI 100W USB-C Power Adapter - DJI Store
This time, actually LOOK at the links I've provided.
Reactions: leonasj
maybe my aliexpress 100w charger is not as they declare. will see at good 100w adapter then.thanks
The question to me is not whether one can supply 100 watts but whether the batteries can safely absorb at that rate. Heck, I could come up with a 1000 watts pretty easily, but I bet the batteries would look like fritters. An ancillary question would be long term effect on the batteries charging at such a high rate. If DJI recommends charging at a specific rate, that is what I would stick with.
The 3S charging cradle determines the input charging wattage - not the output of the charging brick. So, a 1000W brick would still only supply 100W. There is a handshake going on between the brick and the charging cradle (assuming the brick was properly designed). DJI sells a 100W charging brick that it states is compatible with the 3S. Therefore, 100W is within their spec. Also, a while back, a charging graph was posted by me. It shows that a 100W capable brick will only supply 100W for about the first fifteen minutes, then throttles down (this, starting with a battery drained to 5%). The difference this would have in the overall life of the battery (vs using a 65W) is not known - but I can't believe it's significant.1745426741786.png
Reactions: tstr14
The 3S charging cradle determines the input charging wattage - not the output of the charging brick. So, a 1000W brick would still only supply 100W. There is a handshake going on between the brick and the charging cradle (assuming the brick was properly designed). DJI sells a 100W charging brick that it states is compatible with the 3S. Therefore, 100W is within their spec. Also, a while back, a charging graph was posted by me. It shows that a 100W capable brick will only supply 100W for about the first fifteen minutes, then throttles down (this, starting with a battery drained to 5%). The difference this would have in the overall life of the battery (vs using a 65W) is not known - but I can't believe it's significant.View attachment 182086
im tried 140w powerbank and its same —only 60w speed power charging air 3s battery hub.
Reactions: tstr14
Are you using a 100W rated USB-C cable? The one that DJI supplies with the 'fly more combo' kit isn't rated for 100W - you'll never get 100W in with that cable. The other issue could still be the powerbank . Not all powerbanks can successfully handshake with the charging cradle to supply 20V X 5A, which is needed to achieve 100W input (power = current X voltage). And are you testing with a battery drained below 10% ?
That thread where I show the charging cradle getting 100W input has all the links for a power brick and USB-C cable that work (a little cheaper than getting the OEM 100W brick from DJI).
Reactions: leonasj
cable essager usb-c to usb-c, powerbank shows 85w if connected both 3s hub and flip drone to charge both. so powerbank trqnsmits 25w to flip and 60w to 3s battery hub.
yes, battery is lower than 10% always fly. will try another cable
wang
