100w home charger for air 3s
Are you using a 100W rated USB-C cable? The one that DJI supplies with the 'fly more combo' kit isn't rated for 100W - you'll never get 100W in with that cable. The other issue could still be the powerbank . Not all powerbanks can successfully handshake with the charging cradle to supply 20V X 5A, which is needed to achieve 100W input (power = current X voltage). And are you testing with a battery drained below 10% ?
That thread where I show the charging cradle getting 100W input has all the links for a power brick and USB-C cable that work (a little cheaper than getting the OEM 100W brick from DJI).
hello,finally got 100w cable and yes,im got 95w charging speed for my air 3s battery hub.
Reactions: Mrktn
so, my 3s and abat2 takes 100w charging speed , and my flip ,nep and mini4pro takes 35w speed charging? correct?
I only have experience with the 3S (because that's the only one I own).
I just bought the air 3s upgrading from my deceased air 2s, I found out however I need to buy a power brick, I will probably stick to the 3 batteris right now and I usually shoot up to 6 or 8 hours events which requires continuous battery use and flights with no downtime, I can't figure out however which 100w powerbrick will work with the dji hub or even if I upgrade to the:
LKTOP 200W Air 3/Air 3S Battery Fast Charger Hub for DJI/Specta Air 3 Series Drone USB-C Power Adapter, with Gather Average Electricity/Fast Charging/Storage/LED/Alarm Mode, LED Display Screen
This one needs TWO 100w for max performance...
My second use case is charging the drone while in the car for work related, can I use a 200w inverter to charge my batteries while in the car using any of the above two chargers or inverter is not meant for that ??
Finally am considering this but it charges two batteries only simultaneously within 75minutes...
Is it any good ?
Plz guide me to get best chargers while not spending a lot on money on chargers...
So guys back tot he same subject, is this reliable ? Considering all the safety features, not cheap, got an LED screen, and charges 2 batteries in 75 minutes ?
I tried something similar for my late air 2s and I gotta say it was phenomenal charging two batteries in 1 hour...
basri
