1st Flight - Sugar Land, TX - (Taken from Oyster Creek Park)
Edison Carter
First flight with Mavic. I'm not a professional by any means.
This is with a sun-shield only. No lens filters.
Used Autostitch to create the pano.
The main area of park is bottom left-of-center where the white canopy is (I need to work on centering better). The photos were taken from roughly 100m/400ft altitude. TX-HWY 6 is running horizontally through photo.
@Chickenskat Thank you!
I've got a higher res version but it's nearly 50MB in size but that's a bit excessive for my novice photos. This is one is reduced down to only about 5MB so a lot of detail is lost.
The photos were taken with default settings so my next attempt should be a little better with some settings tweaks.
Going to try and make another attempt later in week after tropical storm Cindy clears out.
nikt_elo
