2 controllers and one drone
RobotBee
Hi
Is it possible to have an Air paired with two controllers at the same time? Not switched on at the same time, but just so when the battery for one controller runs out you can just turn the other one on instead, without having to go through the whole pairing process?
Thanks
WRONG CYBORG your missing out , don't work for the air only mavic 2
Reactions: THE CYBORG
Totally forgot about the secondary controller setting for the M2P so thank you for reminding me.
It is now so obvious why the standard controller disconnected when I paired the SC.
I now have the original set as secondary and things look good Thumbswayup
Rythorne
