2d options for 1 square mile (640 acres) photo
Nunabusistan
I'm not sure if this would be called an orthophoto or a photomosaic but I'm looking to create an overhead 2d image of a golf course community that is around 1 square mile. This is to create a pretty photo that will be used for marketing, it does not need to be a large file size that can be zoomed in on to see fine detail or for any survey purposes. I also have a Mini 3 Pro if that would be easier.
I did a 36 image panorama in Lightroom as a test which came out great. Covered an area of about 1/2 mile wide at 400 feet of altitude. Very little overlap, maybe 10%, flying manually. Automating the flight and photo taking would be great to remove the chance for user error. My other concern is maxing out Lightroom's panoramic merging capabilities once I move to a larger area, or at least my computer's hardware abilities. I could do it in stages though if needed. I'm wondering if anyone has any insights for a good workflow for this little project. I've heard dronelink might be a good option.
Reactions: Phantomrain.org
Use DroneLink to generate your mission.
If the property is too large split into multiple missions
70-75 percent overlap
12mph
Altitude 285ft AGL
Expect 3000+ images.
Processing:
I use WebODM. For a large job like this, I would use their online lightening node.
Post it online with a tool like PolyCam
For 137 Acres it produced 702 photos
Split into 2 Missions
Reactions: WShade
Microsoft ICE could handle it for a 2D project if it is still available. I have it installed but lost the original download zip file. You might find a archival copy online.
Good idea. I tracked it down last year and installed it.
Microsoft Image Composite Editor
It's available for download from CNET.
There's also an online support forum.
Reactions: AMann
Cool, thanks!
OP: if it bogs down, try combining small sections or rows first then combine those resulting images. I used to do megapixel processing with ICE and doing this really helped. It’s not perfect, but it’s great in the ability to combine large numbers of images.
hesitantextraneous
