3 Degree tilt
SoCalSteve
Santa Cruz
I have about 3.5 degrees of tilt on my gimbal. This is a new drone from Beach Camera. Anyone have a solution? Any help is appreciated.
Attached is a photo taken from my M2P, the rotated edit, and a link to my video for reference.
Reactions: Bill combs
View attachment 81850View attachment 81852
i have the same issue with my mpp every so often,inside the go 4 app you can then gonto the gimbal setting and adjust the tilt i’ve also found just doing a assistant 2 firmware refresh helps too
Finally found where the gimbal adjust was. Fixed the problem, then discovered the auto calibration. Ha. Works great. Thank you everyone!
hidnflagn
