3 ft cable anchor
Rchawks
Saint Joseph Mo
For lack of a better description how do you retain the extra cord length when using a iPad? Is it ok to hang over the antenna mount on a MA2?
I have draped excess cable over the antenna pivots of a Phantom 3's GL300 controller and am not aware of it causing any radio connection problems but I don't think I had 3ft to deal with.
It just coils off to the side, in a few loops, next to and below the iPad Lightning port. It is not a problem at all. Just put a tie wrap loosely around it, to keep it coiled.
Reactions: InvisibleName
Or you can buy this and the problem is gone.
Thank you I do think that would solve it. I'm not sure how I overlooked this product it's like looking all over the work table and not seeing the screwdriver you're looking for right in front of you. Thanks again.
That's a new product! Glad someone finally filled the void! Thumbswayup
Reactions: bp328i
Finally, someone made one. Thanks for posting!
I starting to lean towards a ipad mini I think for a display so my wife can have here ipad back while I'm flying. Not sure how limiting the 32 gb version would be for the MA2. It will only be used for flying but I'm thinking along the lines of 64 gb. Could anyone fill me in on what capacity they would suggest.
My 32gb is fine. I even use a 16gb for flight only mini 4.
Reactions: Rchawks
Yeah, I'm thinking I'll be using a sd card anyway so not much memory will be used except for the flight recordings.
...it's like looking all over the work table and not seeing the screwdriver you're looking for right in front of you.
Or using the light on your phone to look for your phone. Not that I’ve actually done that.
(Narrator: “He has indeed done exactly that.”)
  • Haha
Reactions: Rchawks
pulasthi
