3rd party battery chargers
getho
Australia
2 questions:
Does anyone know if the type in the fist pic attached is current limited? If I connect this to a 30,000 mAh 60w battery pack with pd3 I should get fastish charging, right? I don't know if I trust the car cigarette lighter types for on the road charging.
I've seen posts about multi-charger but both types available in Aus are only 2amp 150min chargers. I often charge during a job so an extra hour to fully charge is a bit poo. The third type (end pic) is 4amp but no storage charge option. Are these ok, or will they stuff my batteries?
I've been using the blue three lead fast charger for a while now, charges 3 batteries a lot faster than the standard one at a time DJI charger, my batteries are working fine, have 5 now, so needed a way to charge them faster than one at a time.
Reactions: getho and ssvdh66
Thanks! Good to know it's working for you :) I ordered the single hub thingo so at least I can charge when I'm out and about, but I'll probably get the same one as you down the line
I've been using this one since early February is it has been great. It's nice to zip the batteries back to storage levels if I get overzealous and charge too many batteries.
That one doesn’t discharge to storage mode though does it? Think I’ve got the same one as you.
My Air 2S one did discharge to storage mode but had a loud fan to cool the resistive circuit as a consequence. Was literally quicker and less annoying to drain the battery in the drone.
vipul olakiya
