4G dongle Mavic 4 in EU
Darkabaz
Netherlands
friends, i was under the impression that the cellular dongle 4G would also work "normally" on the Mavic 4 pro in europe. the Mavic 3 and air3s work perfectly with the 4g dongle in the drone. with the Mavic 4 i can't do that yet... anyone who knows if it will be available? Now its just saying that it is not possible in my region.
And with the cellular dongle 2?
There is a new dongle for the Mavic 4 Pro called Dji Dongle 3 which only works on the Mavic 4. It is currently been given with bundles at no extra charge in China BUT only in China. Again, the rest of us are being left behind.
Humm... The DJI customer service said, the Dongle 2 works with the 4 pro. Also if we check the specs/compatib. From the Dongle 2 the Mavic 4 pro is on the list.
If you are using the RC2 then in theory the Dongle 2 should work because the RC2 uses Dji O4 but the RC Pro 2 uses Dji O4+ which will make the dongle 2 not work. Dji must have closed the servers to everyone for Mavic 4 Pro Dongle use other than China or maybe there is a trick to get it to work. I am waiting for my care refresh to be active before activating my drone then i will do some tests with the 4 Pro and Dongle 2.
Thats strange because air 3s work with rc pro 2 also. And air 3s works also with the dongle 2.
I still think the dongle 2 can be work for sure because of backwards compatibility between rc pro and models like air3s
Not sure currently. What I mentioned is what I was told by the supplier. Do you have the RC Pro 2?
emoylan92
