4k 60fps only on standard video recording?
SamHir
So I've noticed that in almost every other mode, be it zoom, master shots, cine shots, etc. the Mavic 3 always downgrades to 4k 30fps when recording video. I'm assuming that is working as intended or is there some sort of setting to allow for 60fps in those other modes?
Yep, It need the processing power to handle those modes so the frame rate goes down, which is unfortunate. I have switched to only using 4K 60 FPS unless Ii am not able to. It gives you way more flexibility in post and is a lot less stutterey when there is a large amount on motion.
Reactions: SamHir
Thanks! That's what I figured.
Vicktor
