Am I the Only One Using Avidemux as an Editor?
moldorf
Oregon
maybe I should first explain that I rarely take photos. It's almost always video. And mostly, the videos are of landscapes
At first, I was using Avidemux as the gateway editor. I'd have a raw 4K video of a flight; usually 15-25 minutes long. But I didn't want the entire flight in the final video as I always had pauses and hovers while I adjusted settings. So I'd use Avidemux in copy mode to 'chop-out' those unwanted sections of the video. It was a reverse process as I'd actually save a section that I'd want, then move on to the next section. I'd generally end up with 5-10 video sections that I'd simply use the append function in Avidemux to join. Quick and easy for all stages of this process. I'd usually end up with an 8-15 minute video
and it was that 8-15 minute video that I'd move to Resolve, Capcut, Vlogger, etc. and do the final edits. Of course this was after I struggled with the learning curves associated with each editor
but the biggest issue: for example a 12-15 minute video traveling over a landscape at 200-300' altitude at around 25 MPH can get boring in a hurry. So I would always, as an initial edit, speed up the video by a factor of 2, 3, or 4. And it didn't matter what editor I was using, that 'speeding-up' process would always generate distracting artifacts in the final video. Shimmering & wavering and oscillations, especially over uniform landscape like trees or sagebrush. Capcut was the best at mitigating those artifacts, but some would still show up
then I discovered the 'Blend" function on Avidemux. It can speed up video without generating any artifacts. Since I had graduated to using D-Log, I found the LUT/Cube function in Avidemux. Again, it was easy-peasy. And there were lots of ways to fine tune the contrast-brightness-saturation-hues, etc. without using color wheels & graphs.
I'm not dismissing the value of Resolve or Capcut or Premier. I'm just saying for my simpler needs, Avidemux does everthing I need an editor to do and it does it well
DR will do that but like you said, if it's working out for you then there is no way to make any changes.
At some point, the speed and the precision of those "cuts" may become a factor along with the introduction of transitions and if Avid continues to perform then I don't see why you need to stop using it up front. One editor can always do everything 100%.
AKARekz
