How screwed am I?
Reactions: BabyTweety
How do I get the photos and videos off the internal storage?
I tried downloading the DJI Fly app and pairing it to my phone but it wont recognize it.
Reactions: Cafguy
Connect your Drone directly to your P.C. with a cable. What do you mean by downloading the app??
I tried go use the DJI Go 4 app and the DJI GO app but neither would connect to the phone to let me transfer to my phone.
Thanks. I was able to direct transfer to my PC.
Videos of my 2 test flights.
Reactions: jaja6009
You have some cool places to fly!
I live in New Jersey, it's all flat around here!
I would love to map and model the area in your video.
I have ordered the following.
Extra joysticks
New controller lanyard
Screen protector for the controller
4 batteries
2 extra sets of props (plus the ones currently on)
Car charger
128 GB SDHC card Class 10 V30 U3
Prop strap holder
I still need my landing pad, drone skin and the four in 1 charger and then I think I'm set.
Extra joysticks
4 batteries
Car charger
Prop strap holder
Word to the wise... invest in a battery strap to ensure the battery and airframe can't part company in mid flight. This is the Achilles heel of both Mavic models (original and Mavic 2 series), as well as the Air series (up to Air2S).
And if at any point you plan on flying close to built structures: get a set of PGYTech prop guards.
Can you point me in the right direction?
I'm looking for battery strap and it's giving me handbag straps on ebay and amazon.
The other option besides the added weight of the strap thing is to check your battery condition. If there is any swelling on the bottom of your batteries, toss them. They should sit flat on any flat surface. If they are flat, just make sure they click into place when installed in your aircraft.
You mentioned some new batteries. Are they DJI products or aftermarket?
Regarding props, be careful, there are genuine DJI and then there’s junk.
Research.
Research.
DJI OEM batteries and DJI OEM props. Thanks. I'll check them all.
This strap idea is merely a bandaid for a problem that should be resolved in a different manner. The swelling battery basically will disconnect from its corresponding contacts and provide the pilot with an earthbound chunk of plastic along with some other material.
With the numerous(beyond the twenty mark)M2 series aircraft I’ve run through, I have never contemplated attaching anything other than a strobe light. If I ran across a battery that had anything other than a flat bottom, it was tossed.
A wallet should not be a consideration when safety is concerned. If reputable batteries aren’t available, there are other DJI products out there with available batteries.
Be safe please.
0x6e08715
