4th gen 12.9” confirmation
Artemis
Pelzer S.C.
Hi, so since there was a good bit of back and forth on whether the iPad Pro would work with different cables etc I had ordered the pyg cable to test it. It was successful…. Really different experience watching the camera on the big screen, as you can see, it’s fairly short but long enough to fly comfortably from a stationary position. Ill include link below, tested with a mini 2 and 4th gen 12.9
on a side note, I adjusted my gimbal settings today for smoother video, I think the other setting I may need to tweak is roll, it’s pretty jerky when I try to go from side to side… line up with my pad etc Amazon.com : PGYTECH Type-C to Type-C Cable 65cm for Mavic Mini 2/ Osmo Pocket 2/ Mavic air 2/ Mavic Mini/Mavic 2 : Electronics
Btw, I plans on continuing to use that step ladder, it has perfect attachment pints to make a permanent sun shade, so just sit the ipad on the shelf and should be good to go…. Seems to be worth the effort
Pretty cool. I think I might try that with my 27” iMac Pro. 😲
I suppose if the Dji app will run on it it will… as long as you buy their super secret cable 😂…. But anyway.. yes bigger is better, Quite a treat on the 12.9 screen
Reactions: Howard70
ButoonFox
