D
Could be something like that yes. Havn’t checked.Color saturation changed from about 1.0 to 1.3 or 1.4 I am guessing
An ND filter on that clip would do amazing things. In My eyes it’s to bright and when you turn to the right the water and heaven goes in to one. With a filter on you probably could see the differents between.If you guys are into lighthouses you may like this:
Was the orbit done manually or done using one of the modes? Also it looks like its slightly over saturated in some areas whereas some scenes have the right saturation values.If you guys are into lighthouses you may like this:
Nice work....I'm hoping to get some free time and learn how to do editing myself....your pretty good at it..Yes I was using poi - what I do is several turns changing elevation - then in editing I can use one or two of them
