- Joined
- Feb 14, 2019
- Messages
- 587
- Reactions
- 356
Can anyone confirm exactly where in the arms of the Mavic Pro the antennas are located? It’s my understanding that they ARE NOT in the front “legs”. Does anyone have any insight on this? Thanks!!!
One reason I ask is all the replacement legs do not have any type of cavity, nor a connection of any kind, no matter what brand I search for, they do not have antennas in them.Can anyone confirm exactly where in the arms of the Mavic Pro the antennas are located? It’s my understanding that they ARE NOT in the front “legs”. Does anyone have any insight on this? Thanks!!!
I've seen refernces to the Mavic antenna's being in the front vertical legs, which is why you need to get the antenna's on the RC controller standing vertical when in use ... the best transmission / reception is when the two pairs of antenna's (Mavic & Controller) are parallel / vertical.View attachment 64378
True.. let me look for other examplesIn the picture you post above there is no way to tell if there is a cavity that runs the length of the Mavic Pro's front legs as the shot of the product is from straight on and not top down.
Friggen fantastic!!! Thank you! I stripped the bit on my driver set and waiting on replacement. Is that the right or left leg?Here is the way that the antenna looks and the cavity within the leg
The gps and one of the compasses are right above the wifi board on that back. It's attached to the top shell and then shielded. I'm in the process of hacking both and increase. Already did controller with alientech pro ?What BD0G said. There's even a diagram of the drone in the manual that shows you the location; for the Mavic 2 Zoom/Pro (v1.8 of the manual) it's on page 9 and it clearly indicates the front legs. Perhaps you've seen a reference to the GPS antenna location though? That's a seperate thing and may have a different location somewhere in the main body.
First response since Feb 2019... 2 years ago!The gps and one of the compasses are right above the wifi board on that back. It's attached to the top shell and then shielded. I'm in the process of hacking both and increase. Already did controller with alientech pro ?
Welcome to the forum, Lou!The gps and one of the compasses are right above the wifi board on that back. It's attached to the top shell and then shielded. I'm in the process of hacking both and increase. Already did controller with alientech pro ?
