Don't risk it, I don't see any advantage in not using the OEM props
thats really a loaded question ",good" being the operative word ,there are aftermarket props out there ,but whether or not they are any" good ",or even better than OEM is an unknown quantityHas anyone found any good after market props for the mavic mini?
You call on whether to be put on the spot or not - any recommendations for 3rd party props? You can always claim no one briefed you on that topic! (g)The OEM props deform far too easily, which results in the uncommanded descent problem.
I guess that is a risk, but what if the third party props are deformed out of the mould, designed badly or are unbalanced.
Then they won't work properly, obviously.
The point I was trying to make is that OEM props would have less QC issues than third party props, even though they sometimes have prop strikes but that is a MM design issue.
As you have tested in another thread, third party props don't add really add any benefit but may cause other flight issues.
The fact that master air screw Does not have a model for mini Is telling.Probably wait for Master Airscrew to come up with some. They make props for other Mavic models that have been of decent quality.
I’m sure they tried and perhaps realize it’s an overall design problem with the drone.
If you can’t solve the strike problem then what’s the point.
