Air 2 SD card won't allow deletion on my PC. Help!
Ntexguy
Am I missing something? For sometime now, I have removed the SD card from my Air 2, put it in a card reader and downloaded to
my PC. All works fine, but recently, when I try to delete all from the card, the delete ' X' is grayed out. I am aware of the little 'slider' on
the SD but that is not the problem. I have tried different computers and different card readers....no luck. Thoughts?
Mike
Wichita Falls, TX
The best way to delete all the files from a microsd that you plan to use in your drone is to format the microsd in the drone itself. It's impossible to tell exactly why a computer is not working the way it should since there are macs and pcs and trash and recycle bins, files get "locked", etc.
Delete All = Format so I guess you can try that with your computer if you have to.
Reactions: Nanny Ogg
Just format the card.
It makes no difference whether you do it in the drone or in the computer.
utahloanrelief
