Good day. I don`t have a drone but considering buying air 2s for regular flights but also to use it like above mentioned. There is no info on the internet for standby (non flying operations) battery times. Some people considered 3 hours with some mathematical calculations. The drone still running all systems and processors except flying. It will be interesting how much will last in photo mode on the ground. I have friends informed me that with no battery left on the ground they still can use it for about 10-15 min. Some used it handheld but no battery information. Suggesting that will be somewhere between 1-2 and 3 hours but there is nobody to confirm that.Hello from the Crossroads of America Vgramatikov.
Since the MA2s has a cooling fan and it shouldn't overheat, get a stopwatch and see how long it stays ON while watching T.V. or something else to pass the time.
The app should display the battery level % as you are using it. Obviously it won't show the flight time since you're not flying.
Good luck and welcome to the Forum.
thanks man Nice info.I have never just let my Air 2S run as a ground camera without flying but I have let one of my older drones run in my living room to bring the battery down to storage level. I can tell you it took all night and then some. Way longer then the 24 minute advertised flight time. If there is nothing taxing the battery then it should last for hours.
I’ve done it on my MPP to capture time lapse of near field objects. I’ve recorded for over an hour with no problems. Didn’t use an external fan. Here’s the results of time lapse of events that occur longer than a drone can fly… pay notice to the movement of sun shadows.Hi there,
I wish to know how much battery life i will expect from Air 2s while mounted on tripod(on the ground) and used only for remote photography and monitoring. (no flying, no video, only monitoring and photography).
Great news!I’ve done it on my MPP to capture time lapse of near field objects. I’ve recorded for over an hour with no problems. Didn’t use an external fan. Here’s the results of time lapse of events that occur longer than a drone can fly… pay notice to the movement of sun shadows.
Yeah my maan. Good info. So up to about 3 hours max. How was the overheating?Well, for what it's worth, I put this thread to a test when I got home from work.
The MA2 uses the same battery as the MA2s, so I started with a fresh battery ( 46 cycles) 2 hours and 40 minutes ago with 6% left.
It's 80° F, partly cloudy, and the MA2 was on the deck just chillin' in the shade with the props off for safety.
I have seen a hand gimbal like this that might be handy if you want to be portable.
11.21US $ 13% OFF|Handheld holder Tripod Stable Bracket Mobile Phone Clip Mount For Dji Mavic air 2 /Mavic air 2S Drone Accessories|Landing Gear| - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
You could use this set up as a remote PTZ (pan,tilt,zoom) camera.
If you long press on the screen and drag your finger, you can move the camera around to see stuff. The zoom works too.
Have fun experimenting.
Nice. Check it out some images with Sony rx0 (similar sensor size) but only 20m wi-fi range. Its much smaller and stealth btw but the drone provides more comfort and range. Price is similar but with the drone you have a drone at the end of the day.No heating issues.
The battery levels were green in all cells and the temperature of the battery was 44.5 C / 112 F.
What a great video, and your video "After the Winter" is remarkable. Never seen anything like it.I’ve done it on my MPP to capture time lapse of near field objects. I’ve recorded for over an hour with no problems. Didn’t use an external fan. Here’s the results of time lapse of events that occur longer than a drone can fly… pay notice to the movement of sun shadows.
I have to agree the After Winter video is just great. Loved the winter to spring transitions. Care to give a little tutorial on how its done or point me to a youtube video on the process?What a great video, and your video "After the Winter" is remarkable. Never seen anything like it.
Read the youtube comments including the replies. He mentions "how" there.I have to agree the After Winter video is just great. Loved the winter to spring transitions. Care to give a little tutorial on how its done or point me to a youtube video on the process?
Okay thanks for the heads up. I think most of it is a layered transition where one fades out to give way to the under lying video but the one that starts at 2:38 and rolls away rather then fades is really cool.Read the youtube comments including the replies. He mentions "how" there.
I would like to learn more, though, like you.
