Air 2S- Desperately seeking more upward gimbal tilt
Paulomatic
North Little Rock, AR
I've had my Air2S for almost three years now and am astonished to find myself taking more pictures of the sky than of the ground. Turns out the sky is intermittently fascinating here and I love stitching panoramas. Panoramas were the thing that got me started in digital photography way back in 02 or 03. I also do a LOT of stationary time-lapse, which the 2S does surprisingly well.
I desperately need to access more upward gimbal tilt, and I'm willing to do almost anything. Most of my sky shots would be much better if I could shoot two row panoramas. It would be useful if I could get to the zenith with the top of the frame, but not essential.
The gimbal is capable of tilting up to 45 degrees. Maximum manual controlled tilt is 24 degrees, the excess tilt is used for stabilization of the gimbal.
I don't need that much stabilization most of the time. I'm stationary for panoramas and time lapse, and don't typically fly in super-high wind.*
Yes, I know I will catch the propellers in some shots- not a problem. I mostly shoot blended AE brackets and ghost removal can fix that. Also, I shoot with huge overlap for panoramas so props would get automatically cropped out.
The LItchi documentation claims it gives 30 degrees upward gimbal tilt. Is this true? Has anyone done a comparison? If it does, that would mostly solve my problem- it would let me shoot a two horizontal row sky panorama.
What are my other options if Litchi won't do it? Could the gimbal be recalibrated so its neutral position is 5 or 6 degrees up? I don't think it would be much of a problem if I was then restricted to 85 degrees down. Or am I going to have to take extreme measure like custom-building a camera drone?
*I do occasionally fly in very high winds shooting approaching thunderstorms and have hit gimbal locks frequently. Last week watched it get blown backwards at about 5mph. I dropped from 200' to about 40' and the wind gradient let me go forward again.
I am sure if you are very good at python language and there are a few of you around it could be done possibly? the motor stops probably prevent that. The gimble rides on a plate maybe you could put cotton or something really soft under there or maybe if you have access to a 3-d printer make some sort of wedge for the clips ?
The Controllable gimbal pitch angles are stored in the drone's firmware.
NO 3rd party controll app can override these values.
You would have to edit these values in- and reprogram the firmware of the drone.
Usefull links:
For specs, here they are: Gimbal's Tilt Angle Specifications and Control for Your Drone
and the Air 2s is:
DJI Air 2S-135° to 45°-90° to 24°
Where the second number is the controllable range and the first is some kind mechanical limit.
The FOV on the Air 2s is 88 degrees. If that were so, 44 degrees + 24 degrees leaves you 22 degrees short of capturing straight up at 90 degrees. How about an anamorphic lens that claims to widen the angle by 15%?
I hesitate to try to combine the FOV in degrees (that I do not believe the spec anyway; the specs give a single number and the format is not square) with some sketchy term like "desqueeze factor" and the maximum gimbal angle but surely a wider FOV will capture more sky even if it doesn't give my guess of a FOV of 101 degrees or +/-50.5 degrees. That gets you to 75 degrees, still 15 degrees short but closer.
See comment below.
I would consider try to hack the angle by putting the drone in sport mode and max. accelerating backwards to give a full lean pointing up or close to it. Can you lock the gimbal on an Air 2s?
I have a Mini 3 Pro and previously a Parrot Anafi; both can look straight up and straight down. Looking at 360/360 panoramas with VR goggles is lots of fun and can really capture the feel of a place. If you don't follow VR, its worth noting the Meta Quest 2 can be found very cheap.
Good luck!
That's the diagonal FOV.
The vertical FOV with an aspect ratio of 3:2 (photography), is only 56°.
Info:
Exactly, WIDEN. The vertical FOV is not effected by an anamorphic lens.
Usefull links:
I was very doubtful of Litchi's claim. Is this firmware change the sort of thing a competent repair center could do? At a reasonable price? We used to hack certain brands of cameras where it was very easy to load custom firmware. I suspect our drones are not like that.
Upgrading to an Air 3 would be your best option. I have the Air 3, and it has so much uptilt on the gimbal that is more than anyone would realistically need haha.
Reactions: Phantomrain.org
I used to take pictures of just the sky until I learned this.
A lighting bolt in the sky is cool , but a lightning strike over its subject matter is Epic. Thus having more tilt on the gimbal was of little use.
This picture you took of the storm clouds was good but had you have captured those clouds over something interesting would have been amazing.
This is why I focus and frame most of my shots now on the Subject beneath the Storm.
Just to give an Example : Had I just captured the sky it would not have been as epic as this picture , so keep your gimbal lower is my moto..
Phantomrain.org
Gear to fly your DJI In the Rain , an Capture the Storm.
Hx30326
