Air 2S landing gear recommendations
You can find several commonly used landing gear options here on Amazon.
I don't think any supplemental gear is needed. I've never had a problem with the Air 2S landing safely and stably. What benefit are you anticipating from adding something to the drone? It's already very stable on landing and any added ground clearance from landing gear extensions will not provide any significant protection from dust and grit.
Land it on a flat surface and hover for a few seconds to blow away any loose soil, leaves, and other minor debris.
Reactions: bassnbeau
Robby1983
