aircraft disconnect
michael.u.solis
Has anyone encountered aircraft disconnect in certain areas and not on some areas. what seems to be the problem? I already bought a dedicated samsung android to use for the drone without sim so no disturbance. any suggestions? thank you
Is the aircraft disconnecting from your controller or are you just loosing the view from the mobile device ??
Definitely. Seems to happen randomly. I've noted that often it's more about where I'M standing versus where the bird is. I've also had really good connections one day, and then have a very different experience at the exact same spot on a different day. #GREMLINS
Huey0315
