Aircraft lost connection with RC. What happens?
Freddy K
Valencia, Spain
Hi everyone,
I just had a scary moment while flying my Mini 2. I was flying back home (manually), still about 200m away, 4 bars of signal, when all of a sudden, the video turned grey and the message "aircraft not connected to RC" appeared.
I didn't panic, but instead tried positioning the RC to the direction of the bird to reconnect again. This took about 30 seconds.
To my surprise however, two things had happened during this time:
1. The mini 2 had initiated a RTH and had already started ascending, which makes sense because it had lost connection
2. The drone was NOT where I expected it to be. Apparently it had kept flying in the direction and speed when the connection was lost until the RTH was started. Checking this new location, I realized I was really lucky, because 10 seconds further, big trees were waiting to embrace the drone.
My question: if the connection between drone and RC is lost, is it normal that the drone keeps flying instead of remaining in the same location (for safety)?
Then, if the connection is not restored after a while, start a RTH?
There is some 'braking distance' before the drone will halt.
Of course there is also the retrace that I forgot to mention but I see that Meta 4 has covered that.
See
From memory there are either two threads in here about that flight or one thread here and another thread over in the DJI forum.
You might post the log for the flight and if there is a separate log for the reconnected portion of the flight, could you post that too ?
Your question is answered on page 15 of the manual:
Failsafe RTH
If the Home Point was successfully recorded and the compass is functioning normally, Failsafe RTH automatically activates after the remote controller signal is lost for more than 11 seconds.
When the firmware is updated to v1.1.0.0 and above, the aircraft will fly backwards for 50 m on its original flight route and ascend to the preset RTH altitude to enter Straight Line RTH.
The aircraft enters Straight Line RTH if the remote controller signal is restored during Failsafe RTH.
When the aircraft flies backwards along the original flight path and the distance from the Home Point is less than 20 m, the aircraft stops flying backward on the original flight route and enters Straight Line RTH at the current
altitude.
In DJI Fly, users can change the settings of how the aircraft responds when the remote controller signal is lost. The aircraft will not execute Failsafe RTH if land or hover has been selected in the settings.
Wait for the GPS lock before launch, else the drone will randomly choose a homepoint midflight that doesn't correspond with the real homepoint.
Reactions: careless
The choice of home point location would not be "random", it will be where the drone first acquires sufficient satellites to set the home point.
Thank you for the feedback.
The link to the other post was interesting, especially the trial of purposefully turning off the controller to see how the drone responds.
I have been looking to the flight recording that is available in the DJI Fly app and it did mention the moment where it lost connection and when it started the failsafe RTH, but it doesn't say when it got reconnected again.
I tried finding the log file on my android phone, but can't seem to find it. According to the sticky post on the forum about retrieving log files, it should be in
DJI.go.v5/flight record
but this subfolder doesn't exist.
I also did a search for DJI*.txt on my complete phone: no success either.
Any idea what I'm doing wrong here?
Have these files moved to a different location recently?
Failsafe RTH
altitude.
I had the exact same thing happen to me yesterday flying my mini 3 pro at about a distance of 850m from RTH point. Fortunately I got a satellite lock before taking off
I had the same experience 2 days back, also went to fly in an old spot I knew I had trouble before....this time the screen grayed out as well, signal red, its says signal lost! Panic sets in by this stage, did hit the RTH, but I thought the drone had already fallen from the sky. Whooo after a few heart stopping seconds I could see the screen come alive as well as picture! The reason is a cellphone tower is near, but I can fly around it, but there is a microwave big dish on the northern side and I flew through the signal I believe, I did see the other tower in the same direction as where I lost it, same height as dish, about 70 to 100 meters away. Seems on the video that the drone did not fly on on its path but stopped, luckily for me phew...
In certain circumstances, I have never figured out what they are, a reconnection will trigger the creation of another .txt flight log.
Where that DOES NOT happen and the old log continues, you will generally find "drone reconnected after 'xyz' seconds", or similar, in the comment columns on the extreme right of the phantom help CSV. Thye airdata CSv mayshow something similar.
In addition, if you look at the "OSD.flyTime" and "OSD.flyTime " of the Ph csv their time stamps will jump from the disconnection time to the reconnection time without incrementing.
Is the Mini 2 different to the Mini 4 Pro in that respect ? Mine doesn't even change to flight permitted until it has established a home point, so I can't leave the ground without one ! Or CAN I take off when the messages are yellow / before GPS has enough sats ? I've never tried it !
It's irritating that DJI makes these significant changes in RTH behavior across firmware releases. In this case, FW 1.1.0.0 and later, vs. earlier firmware.
The backing up was introduced in 1.1.0.0. This makes sense for the Mini 3 Pro and Mini 4 Pro, they have backwards OA. The Mini 2 backs up blindly, which doesn't seem too smart.
Second big change: When closer than 20m, RTH would just land in place. 1.1.0.0 now hovers, leaving the pilot already familiar with RTH behavior who just updated his Mini 2 probably thinking somethings wrong, and RTH isn't initiating.
These seem, to me, wholly unnecessary changes for the Mini 2.
I can certainly launch a mini 2 with 0, zero, satellites.
I would be surprised if you can not do that with a mini 4 pro.
You might have to acknowledge/touch a low light warning and then accept responsibility for the flight but, providing the ground is well enough lit and has a clear and well defined pattern, the drone's VPS system will work and provide position holding whilst the drone is low enough.
However, I reollect the mini 2 is restricted to a height of 5m if there is poor GPS but I think the Mini 4 pro might be able to go higher than that.
Just be careful you don't climb out of the range of the VPS sensors, as that is likely to put the drone into ATTI mode.
The other thing to remember is that the homepoint will be set to wherever the drone is when it first gets sufficient satellites to establish its position and you may have to reset the homepoint to the controller's position.
Heraklit0469
