can the tablet be wifi only or does it need to be cellular. I would use my cell phone as a hot spot.
No need for cellular unless you want to reset HP to the RC. Easier to just reset HP periodically to the current drone location while drone is following you, like flying from a boat.can the tablet be wifi only or does it need to be cellular. I would use my cell phone as a hot spot.
I don't know why it's all about Samsung on here. ?Huawei Mediapad M5 10", works perfectly....
Absolutely agree....better in many sides and cheaper...I don't know why it's all about Samsung on here. ?
I've now moved on from Samsung. Huawei all the way.
Using M3 & M5 8.4 inch Mediapad & P-Smart Mobile 6.2inch
All run perfectly with the DJI Fly App.
You having a laugh ?? You must have been looking at the Light and cheaper versions.I had checked a few of these previously and almost picked one up but the screens don't appear to be very bright (401 nits).
The real one is running at 2560 x 1600 pixels and that is hard to beat.
i know --- shoot me now!Seriously? another one of these threads?
what samsung tablet will work with the mavic air 2
When I was flying my Pantom 3 Pro with the SamsungScreen resolution doesn't determine how bright the screen is though. I'm referring to the brightness, not the resolution. A device can have a beautiful, high resolution screen but not be very bright.
All my Huawei's can't be used in normal conditions on full brightness, too sore on the eyes.Screen resolution doesn't determine how bright the screen is though. I'm referring to the brightness, not the resolution. A device can have a beautiful, high resolution screen but not be very bright.
I "third" the reply Samsung Tab A 8 inch....On sale new last month $129. Excellent thus far except my difficulty in getting a long USB-C to USB MicroB cable to use with it. I have been told to look for an OTG type USB cable. the 5 that I purchased were probably not even though as advertised on Amazon, said they worked with the Mavic. Only the short cable supplied by DJI has worked but then I need to shift the Tablet way over to the left for it to reach the MicroB input. Have a 3 footer Pearlstone cable on order.......Overkill but was the only one I could find. If it works, I will need to wrap it around the antennae a few times.I second DorJammer's recommendation of the 8" Galaxy Tab A. Works great.
