Annoying, no return to level of Gimbal
Bad Santa
So, one of the things I find sort of annoying is the lack of a fixed gimbal setting. A one button that could be set to either a preferred angle/zoom or at least to level with the horizon.
I've found that it can look like you're clear of an obstacle but because of the angle of the gimbal it is misleading.
I wish you could have a "return to setting" programmable setting. Maybe program it into one of the buttons.
You should share this with DJI directly. They likely won't ever see your wish here.
Reactions: GeorgiaPI
Reactions: Bad Santa
Fair enough - just checking OP knew about the existing functionality. Quick double click on C2 (in my case) has been resetting mine level a treat ever since I had it !
Your suggestion is something to consider.
Some would say to not post a subject like I did because DJI will never see it, but then you get people posting helpful tips.
Thanks.
Reactions: AeroJ
djimini3
