Another reason to leave iOS and pick up a wonderphone
Only if you scan the receipt from apple genius bar confirming that you put $$$ in apples pocket. :D
Seriously, though, these c(r)ooks should be sued out of existence.
Not sure what Dave Grohl has to do with anything
People are going to hate on Apple. There is no getting around it. Regardless of what they do, why, and how, people are going to hate it. The average person (especially Apple people) doesn’t keep a cellphone 2+ years, which is longer than the average lifespan of a cell phone battery anyway. I see no problem with this what so ever
May I ask how to do a factory reset on the iPad mini? It might help.
Mine works perfectly until it gets hot, which seems to happen toward the end of most maximum length flights when caching, except in really cold weather, and then the video feed goes spastic making FPV really scary.
I recently factory reset my 2+ year old iPhone 6s Plus and it has been blisteringly fast, noticeably faster than a friend's 1 year old iPhone 7. Try to factory reset and see if you get similar results :)
What method did yoy use to factory reset your phone, thanks?!
There's no way Apple will allow users to replace their own battery that easily. People would buy the cheapest battery they could find, and it could lead to so many potential problems. Then they'd blame Apple if their iPhone batteries blow up. It was bad enough that people buy cheap chargers, causing fire, and Apple had to deal with the PR over that.
It's like buying cheap knock-off props for your $1000+ mavic.
And if the article is true, others will conduct their own tests, and hopefully Apple will quietly fix this 'feature', so the problem goes away.
iPhone battery replacement is a 5 minute job....10 if you've never done it before. It's really simple.
Screen replacement on iPhone 6 and newer is also about a 5 minute job.
iPhone 4 was about a 45 minute job to replace screen, but still 5 mins to swap battery.
dvkhamtruocsinh
