Anyone having a problem with Maps not showing
jaysrmc
Phoenix
I used several different methods but the NOSECNEO version does not show the here maps.
I used a older version that works but want newer features. I also have this problem where my RC says NFZ when I am not in a NFZ. It goes away after a few minutes but it still odd.
The Here maps license expired. The only way of getting it back, is to change your date on your device you are using. Make sure you are not connected to internet, otherwise it reverts the date back, then no map again.
Im having same problem for about a month or 2. Im using Android and 4.1.15 . So changing date will work? I will try tommow.
CTD
