ATTENTION ALL PILOTS! Mavic Mini falls from sky into the water! LOG READER NEEDED!
Status
Not open for further replies.
This is another case of the Mini failing to achieve specified tilt. At the end of the flight it did not consistently even manage 10° tilt, when the specification is 20° for a wind resistance of 8 m/s.
While that led to multiple wind warnings (see below), those are moot if the aircraft can't reach 10° tilt. I suspect that the DAT file (FLY062.DAT) will show that one of the rear motors was maxed out at 8°. Worth a look if you can retrieve it:
Flight log retrieval and analysis guide
0.0 0.0 IN FLIGHT0
0.0 0.2 6.2 0HOMEPOINT UPDATED. RTH ALTITUDE ADJUSTED TO 39 M!^RZ
9.2 39.2 XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
39.2 STRONG WIND WARNING
39.2 JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!
47.2 47.2 IN FLIGHT0
47.2 107.8 AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
107.8 (MAX POWER LOAD REACHED. FLY WITH CAUTION
118.2 118.2 JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!LC)
122.3 XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
125.2 125.2 IN FLIGHT0
125.2 153.2 XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
153.2 STRONG WIND WARNING
153.2 JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!C
157.3 163.2 AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
163.2 (MAX POWER LOAD REACHED. FLY WITH CAUTION
163.2 163.5 163.5 IN FLIGHT0
207.2 XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
207.2 STRONG WIND WARNING
207.2 JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!-
225.2 225.2 IN FLIGHT0
225.2 239.2 XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
239.2 STRONG WIND WARNING
239.2 JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!
302.2 302.2 IN FLIGHT0
302.2 406.2 XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
406.2 STRONG WIND WARNING
406.2 JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!R
439.2 439.2 IN FLIGHT0
439.2 454.6 AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
454.6 (MAX POWER LOAD REACHED. FLY WITH CAUTION
475.1 475.1 IN FLIGHT0
538.2 XSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME (CODE: 30149)
538.2 STRONG WIND WARNING
538.2 JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!
545.4 546.2 AIRCRAFT MAX POWER LOAD REACHED. DECREASE ALTITUDE AND FLY WITH CAUTION. IF THIS ISSUE PERSISTS, LAND IMMEDIATELY (CODE: 30168)
546.2 (MAX POWER LOAD REACHED. FLY WITH CAUTION
546.2 564.2 564.2 JSTRONG WIND WARNING. AIRCRAFT UNABLE TO FLY STABLY. LOWER ALTITUDE IMMEDIATELY AND MANUALLY RETURN TO HOME!
And also, when I upload this flight log to PhantomHelp it displays that when the drone starts to malfunction, no joystick movements was made, which is weird. I mean I pushed both of the sticks up all the time...
Reactions: Shanie Boy
0.0 0.0 IN FLIGHT0
Hmm.. I can't find that .DAT file anywhere... just the logs..
Do you know if I can't get a refund from DJI b/c of what happened? As you said "
At the end of the flight it did not consistently even manage 10° tilt, when the specification is 20° for a wind resistance of 8 m/s." Isn't that a fault/malfunction from the drone?
There were so many strong-wind warning messages in the log. Wondering if the OP has seen any on the DJI FLY app ?
And also, if you watch the footage that I attached, there were no major wind. Thats why I'm having a hard time understanding why the drone just fell from the sky. I couldn't do anything at all..
Best to contact DJI on this, especially with @sar104 ’s analysis.
Not sure why the Op here started 2 threads on this but
now we have this one and the first.
and I can’t merge them.
We are not going to have 2 threads going at one time .
The logical thing is to close the last thread posted which
is this one so sorry guys blame the OP but post in the first one linked above.
CLOSED​
Status
kholik ibnu
