Avata 2 C1 classification label location
HopwoodBoy70
United Kingdom
Hi all,
I'm taking my Avata 2 to a few European countries in a couple of weeks and am just registering it / registering myself with the EASA. I live in the UK but because our stupid country decided to leave the EU - Brexit - my UK registrations aren't valid in the EU, even though they are identical!! However, I know that my Avata 2 has a C1 classification, but I'm either being stupid or I need new glasses, but I can't see anywhere on the drone itself a label showing the C1 classification.
Does anyone know if there is a physical sticker somewhere on the drone, and of so, where?
Reactions: Cafguy
This is not the avata BUT it is the sticker.
Reactions: HopwoodBoy70
Yep I would ask someone I am not from there BUT the rule does say: "a drone with a certified class label."
This is the C1 sticker on my Avata 2. Should be there on any of them by default. Hope you didn't remove it during unpacking...
Reactions: Cafguy
Hi all,
Sollte auf der rechten Seite zwischen den Propeller sein da steht 81dB und eben oberhalb der 81dB steht bzw sollte ein 1 stehen .Wenn nicht dji anschreiben die schicken ohne Probleme ein neues pickerl. LG aus Wien
So the drone you bought in Germany already had the label applied to the aircraft or just in the box and you had to put it on?
Mamanov Ramazan
