Avata crashed - Need help deciphering log
Um you might like to have a look at Avata is the most dangerous drone ever use
but put on some body armour and old clothes first there a fair bit of 'mud' flying, I gave up after the first page.
But it does seem to raise the possiblilty of control problems at times.
Has you drone had any bumps or bangs prior to this crash?
It would also seem wise to ask, do you know how to cause a mid air shut down of the drone's motors.
Were the all the props on the drone when you recovered it? If not were any completely missing?
...Can anyone decipher this log in order to see what has happened?
The incident is directly related to when you command a rapid full throttle command, the quad quickly tilts nose slightly down & rolls heavily over to the right side & at the same time the quad rotates CCW.
Pitch down = loss of either of the 2 front
Rolls right = loss of either of the 2 right
Rotates CCW = loss of either front right or rear left (these 2 apply CW rotational torque)
All this together clearly points to a rapid thrust loss in the front right corner... this either due to a prop or a motor failure.
All relevant data in the chart below... chart marker placed just when the incident starts & values in the legend is from that point.
(Click on the chart to make it larger)
Reactions: BudWalker
GLobus55
