Battery Fault
billiam1
AU
Hi Guys.
One of the batteries is saying it's charging, when it's already charged (4 continuous blinking lights instead of solid lights)
any idea what's wrong with it?
Thanks in advance.
ps...it's a Mavic Mini 1
Hi Guys.
Thanks in advance.
@billiam1 is it blinking when its still on the charger, or do you mean after the lead from the mains adapter is disconnected from the charge hub,it does take quite a while for the lights to go solid ,as the last portion of the charging process is when the cells are balanced and all 4 lights will continue to flash till this is achieved
It's blinking when it's on the charger, the other 2 batteries charge up OK
what you could do is put it in the hub on its own attach a load to the output USB of the hub press the button on the hub and see if it starts to charge up the phone or other device that you have attached, leave it for a while and see if the lights start to go out as the current is being drained, then keep going till you have one solid and one flashing light ,then with just that battery in the hub connect the charger back up, and see if it starts to take on a charge ,of course remove the device from the USB outlet first
Reactions: shaneb50
Mamanov Ramazan
