Battery stays on after charge
Johnic
I have a battery that has only been charged 3 times. I just noticed the past charge that when completed it stays on with the lights all lite. I have to turn the battery off. What could be causing this? I have two other batteries without this issue. Is this something I should be concerned about.
I also noticed I haven't flown in a couple weeks and I took a battery out of case and it was warm to touch, I assume it was in the middle of self discharge ?
It's annoying but you can disregard it and use normally.
Most likely it will only do it from time to time.
Gotcha. It's wierd. Not sure why it would do that.
Thanks
Your right. Ran the battery down to 50% and it charged without an issue. Let's hope it doesn't keep doing it.
Thanks
proya12
