- Joined
- Jul 22, 2018
- Messages
- 133
- Reactions
- 45
I went out to fly the Mavic 2 zoom the other day and noticed that my batteries are swelling. Can I get any of these re-built or do I need to get new ones ?
Thanks for the information -flat bottom. You can see it if starts to or already is swollen. The Mavic Air one has tiny tabs on the bottom. It will sit flat and not rock until it swells.
After writing something ridicules and dangerous, you not only will not have a chance in a lawsuit, you'll be lucky if you don't get charged.Mavic 2 batteries are rubbish. They start to swell after about 50 hours, and are ridiculously expensive to replace. I suggest you contact dji and complain. Mine are swelling, were made in 08 2018, and are discharged automatically to 66% every 3 days, yet still all swollen. i am going to keep flying till it falls out of the sky, then sue dji for the hopefully resulting injuries, damage or worse. That will show them, especially if it kills someone!
Swollen batteries can also explode when charging, so I'm hoping to burn down my house while charging because of this poor product, then sueing DJI for a new house. I leave it in my car most of the time, so hopefully it will catch fire and burn up my car. I will sue them for a new car also.
In fact, I'll sue them for all of the above now, and maybe they'll replace my batteries. Suggest you try the same. No thanks necessary, but dollars fine.
Hi. I am very sorry that you had such a problem. Pay attention to two important factors that affect the bloating of batteries; 1.this is the use of a battery with a load at high ambient temperatures. 2. when loading on a battery when there is little battery left in it. I would also recommend monitoring the operating temperature during the flight through the DJI Go 4 application, and if you see that the temperature is high, then try to give less load in flight and then I’m sure that the battery will last for a long time. I have batteries since 2018, and no problems are observed. I also recommend storing the battery at a temperature from 18C to 25C maximum.I went out to fly the Mavic 2 zoom the other day and noticed that my batteries are swelling. Can I get any of these re-built or do I need to get new ones ?
This is my fool proof method, in fact sometimes you can get it to spin a lot if it swelled up pretty well.If you can spin it on a flat surface, it's beginning to swell.
Good points. One additional complaint against DJI is their failure to log Battery temperature of flights made with the Smart Controller. Normally AirData will allow you to review a flight and see the battery temperatures. Unfortunately DJI had an update some time ago which broke that logging, at least for the Smart Controller. I understand that using an iPhone as the controller still works. Anyone know what past GO4 version worked for battery data logging?Hi. I am very sorry that you had such a problem. Pay attention to two important factors that affect the bloating of batteries; 1.this is the use of a battery with a load at high ambient temperatures. 2. when loading on a battery when there is little battery left in it. I would also recommend monitoring the operating temperature during the flight through the DJI Go 4 application, and if you see that the temperature is high, then try to give less load in flight and then I’m sure that the battery will last for a long time. I have batteries since 2018, and no problems are observed. I also recommend storing the battery at a temperature from 18C to 25C maximum.
