Beginner
Well like you advised I checked several you tube vids out on FCC each one advices about legal implications about using FCC ??? By the way I’ve just returned from my flight today and used the custom WiFi and changed channel to a good number, I flew for the duration of my battery charge without one single interference, so problem solved thanks again for your help much appreciated [emoji106][emoji120]
If you dont want to move to FCC mode, you can try to select wifi channel with less use.. also try to fly in none residential area for better singnal..
Reactions: Jacamo
Mamanov Ramazan
