I just got the Nvidia Shield K1 and I like it alot. The only problem I have is that the thickness of it makes it kinda hard to fit it in the RC holders. I had to do a little modification to be able to use the tablet without a mount.
sent from my Galaxy Note4
I would be very interested to see how the S clips will hold the tablet in place.Hi!
Just got mine too.
I've ordered me some S-Holders to fit it correctly, but meanwhile I would be interested to see a picture, if possible, of the mod you did please?
Well... I just received them.
So I went to try and I must say I'm a little disapointed because they don't hold the Shield well: it slips, so I have to hold it firmly in my palms, wich is not very comfy to fly the Mavic in the same time.
I'll try to put something to hold it tight when inserted, but I must say I'm still looking for a good solution.
Any hint on the solution you where talking about?
You just need to heat the S clips up and reduce the gap ..
I have a bit of soft glasses cloth between the shield and the clip
Sent from my SM-G925F using MavicPilots mobile app
Still interested in seeing how these S clips install and hold the tablet.If your Tablet is slipping, use some sticky back fabric. You can get sheets from Craft shops. It's soft enough to not scratch but hold your tablet securely.
Sent from my SHIELD Tablet K1 using MavicPilots mobile app
Those are the one I bought.
MAVIC S HOLDER nvidia shield Tablet
Still interested to see the mod you did on your controler.
(SNIPPED THE PICT)
I had to cut away a little on the stop so that the arms could extend further out. I also had to cut away some of the rubber feet that hold the corners of the tablet into the arms. The Shield is thicker than the Ipad mini so u really cant get the tablet into the arms very good unless u take away some of the rubber feet. All in all , it works pretty well. Still getting used to holding the rc with the tablet in it.
Low Profile DJI Mavic Controller to Tablet Adapter by halley
I modified a cheap $8 cover case for my Shield. Works great, super fast to setup, and no chance of scratching.
Any idea if a Dell Venue 7 would work? Been offered one,but not sure. ....I like the Google Nexus 7 (2013) and the Nvidia Shield K1. Both of these tablets have GPS. You can find some other commonly used tablets here.
