Best Trackimo location
Cyberpower678
Hi guys, it's my turn to ask a question. Where's the best place to put a Trackimo? I just got mine, and I'm thinking of putting it in the front above the FVS, since most of the hardware is located in the back including the receivers and compass. Thoughts?
Check out this thread to see some of the usual Trackimo mounting locations.
Reactions: Cyberpower678
I use one of the printed mounts that sits between the rear legs. Works fine. Never had a problem.
I want to keep added weight to a minimum. I already have DJI Prop Gaurds attached in some flights.
I bought a set of prop guards but not had the desire to use them yet. My only addition is the trackimo, a tile on the bottom of that and an additional LED light. No noticeable change in performance or flight time which is surprising.
Robby1983
