Best video setting to eliminate vibrations during turning?
I have not seen vibrations in video while turning, are you perhaps in Sport mode?
No, in normal mode ... it’s not caused by hardware, I believe is related with the resolution and frame rate. I am recording in 2K but I believe it can be improved
You probably need ND filters but without more information it is hard to say.
There should be no 'vibrations' at all ever in any situation, unless you are torqueing around abruptly in sport mode. The Mavic has an almost magical ability to deliver perfectly smooth recordings, unless you are using the goggles head tracking, then it all goes to pot.
playground
