Binding Air 3/RC2/Integra Goggles
propflux01
Central Arkansastan
Hello,
I am having a bit of trouble here trying to make this all work. All latest firmware has been downloaded for all three devices. I got the goggles to bind to the air 3, and it shows what the camera sees, but nothing else. If I turn on the RC2 while the goggles are on, it won't connect. Shows a dark screen saying goggles in use. If I turn off the goggles and Boot the RC2, it links with the air 3 but then the goggles won't. So, I looked online for a dumbed-down version of how to do this so I can use the goggles while controlling the drone with the RC2. My Google-Fu must not be aligned with the stars because I cant find any tutorial except how to bind up to an O3. Maybe I'm just missing something simple or what, but could someone lead me in the right direction in plain speak so I can figure this out? Thanx, in advance.
I don't have Air 3 so I don't know this for sure because things are always changing but I don't believe the RC2 *and* the Goggles will both work with the Air 3 at the same time. Either one or the other. If you want to wear the Goggles, you'll need to use the RC Motion 3 instead.
Oh, that just pegged my fun meter!
So I have to dump more $$ to get another controller to do this. You'd think DJI would make it all work. I was under the impression it would work with my RC2 controller.
Thank you for responding.
I think some people have found a workaround but not sure there is official DJI support just yet. You can search on YT for some of those videos.
Reactions: propflux01
As far as I know only Goggles 3 and RC2 work together. I once flew the Air 3 with Goggles 2 (they should be similar to your Integra) and Motion Controller 2, but not Goggles 2 and RC2. (In my case I already had Goggles and MC2 from my Avata)
.. and I cannot recommend recording videos while controlling the Air 3 with the motion controller: every little movement of your hand will be visible in the resulting video
Fessy
