Black and white lines in bright areas of SC?
rtr32
After latest update...any solutions out there? Thanks
Go to camera settings and turn it off..hit the 3 little dots in upper right corner...then go to camera..it probably went back to defaults after update
@rtr32 a lot of updates will reset the parameters already in the drones memory ,it is good practice before doing an update to go through your settings, and make a note of them ,then after the update check that they are as you set them ,the stripes you mentioned are for overexposure it is called hatching and will appear in any parts of the screen that is overexposed it allows you to alter your EV setting and see what affect it is having
Roll the wheel on the top-right on the controller to adjust exposure to just eliminate the overexposure indication for correct exposure.
Phly858
