Brake sensitivity in Cine and Normal?
parkgt
I am unable to adjust the brake sensitivity in Cine or Normal mode, when the OA is set to Bypass. And yes I had both the controller and the app in the same mode when setting
The braking is abrupt. It can be adjusted in sports mode or when OA is set to Brake DJI tech support tells me this is just how it works and is not a defect in my unit.
Have other noticed this is the way their unit operates. I wish it braked a little less abruptly. Strange that it needs hard braking in Bypass OA but not in Brake OA.
If you have it set to "by-pass" braking sensitivity is unavailable. If you have it set to "brake" then it is. Braking sensitivity isn't an issue if you are wanting the drone to by pass the object
lukejoewalsh
