Broke a leg
BLOGoose
pretty chilly out the other day. Set my mp on center console bumped it with my elbow and cracked leg. Is it safe to fly or wait for a replacement?
That depends, are we talking about the (1) arm or (2) leg?
Those are my own definitions, and I don't expect them to apply with others :)
If its the arm, then no. Stop flying. If its the leg, then I suppose flying wouldn't be much of an issue.
Agreed w/ the above. Just be sure a prop won't hit when it takes off or lands. You might wrap some duct tape on it if you do fly, just to be sure it doesn't disappear int he air and then you are in a situation where you hit a prop on the ground when you land.
That said, if flying is just a fun hobby for you, I'd probably just fix it first regardless.
Thanks guys it’s a front leg don’t want to apply any glue to it might just tape it or heat wrap until I get a replacement.
Reactions: Pcarlsen
I would check with @Thunderdrones to see if he knew where to send ya to get what you need .
Reactions: Former Member
dugan
