Dji assist 2 calibration not working. I’ve disabled undersigned drivers, changed all resolutions. Green box is still not showing up. I’m getting 2 check marks by the sensor but black screen. Please help!!
I think you have to enable unsigned drivers when installing Assistant 2 not disable them.
Whats the point in disabling the drivers that you are trying to install!
Do you have the correct version of Assistant 2
(i.e for any Mavic 2 you need 'Assistant 2 for Mavic' not 'Assistant 2')
You have to have the drone sensor exactly the correct distance and facing the screen as you twist the drone to follow the boxes. My arms got very tired and I wasn't sure that I had pointed to all of the boxes. The calculation also takes quite a while before the update takes place.
