Camera doesn't respond after 1-2 mph crash
pedrof
miami, fl
Camera ended outside in, fixed it but it doesn't answer to any command, except zoom, it do the dance, at the end it moves horizontally very slowly to one side down to 45 degrees and to the other side 45 degrees then it just stay in that position, doesn't answer to the dial or the touch screen movement.
I would love to know the resolution to this. I have the exact same issues after my first accident. I've already ordered a new gimbal & camera but would love to know if theres a much cheaper fix..
Reactions: pedrof
I think there is a RECALIBRATE gimbal option in the app but the controller is elsewhere at the moment. But after a crash, no matter the speed, you might have done some damage but see if there's a Recalibrate option. Good luck
Reactions: pedrof
well, this was helpful cuz searching for the calibrate option I found out the camera icon was missing, then I hit the gimbal a bit and it started to work normally, probably is something loose inside, is not working right now, will dismount it and try to reconnect... thanks guys!
RichardThiery
