Camera image drifting
nyknba
Before take off on a flat surface and while in the air the camera image slightly pans to the side. Is there a fix for this? I’ve recalibrated the IMU and compass thinking that the aircraft may not think it’s level or something but it didn’t help. Is it a gimbal issue?
I thought this problem was already fixed with the firmware update. Do you have the latest firmware?
mine does this some times in flight, i will center for a photo and it will drift slightly, some times tripod mode helps
twin01
