Camera settings
Your photos is definitely overexposed. Check out the "best camera settings" videos here for some advice on choosing good camera settings.
Reactions: charliesRig
Have had the same issues. No matter what we did, the camera was not metering correctly in Auto. Setting to Aperture Priority Mode solved the issue.
I believe the Mavic Pro has a fixed Aperture. It can not be adjusted. You can add ND filters, change the shutter rate, lower the ISO in the manual mode. Try to get an EV of 0 or as close to it as you can.
Look at these YouTube videos:
Reactions: mereflyer
Hatcher
