hi!
i recently noticed when i push stick hard forward in sport mode, camera from center position tilt down little bit, around 10-15 degree.
is it normal or a bug?
thanks
Normal. The pitch of the craft changes downwards when in Sport Mode and travelling fast in the forward direction. To streamline the craft and help cut down on drag.
I could be wrong here (and it most certainly wouldn't be the first time,) but I think the downward pitch of the aircraft is due to the thrust of the props. If it didn't change the angle of attack, it would not hold altitude and start climbing. This of course assumes that the pilot is not calling for a climb with the joystick.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
