Can No Longer Download Mavic Pro Videos????
DownandLocked
Just tried to download a recent video from my Mavic Pro. Removed micro sd card, put it in an adapter and inserted in my PC slot. My PC didn't recognize the sd card. Then, reinstalled micro sd into M/Pro and connect with a USB cable. Turned on M/Pro and computer still doesn't see the card. What's going on??? Worked fine a few days ago.
Are you able to copy files from your computer to the SD card? Seems like your SD card might have an issue.
No. The sd card never shows up in file explorer when I insert it in the PC. Tried two different adapters thinking that might be the problem.
I think it's obviously an issue with the SD card (or USB) then and not the Mavic.
Thanks for everyone's input. Found the problem. Tried a new sd card and all is well. Never had an sd card fail before. No moving parts. Figured they were bulletproof. Could be worse; just lost today's video. Now I've got an excuse to fly some more :).
You might want to do one more check through Computer Management and see if the disk is identified with a drive letter that's already being used by something else. You will be able to change the drive letter to something not being used.
Reactions: DownandLocked
Wesleydjimavic2pro
